1.2 mk2 ph1 cambelt snapped
  1.5 Clio Dynamique
not mine but my sisters
She was doing about 50 - 55mph on a dual carriageway and cambelt / timing belt snapped (i assume they are the same things.)
what are the likely cost implications. obviously the pistons will be bent but is there a rough idea on cost????????
  E36 Coupe & Mk4 Golf
valves will almost defo be bent/damamged seen them be rebuilt for around £500 providing damage is not to bad
Alastair.
  986'S 172ph1+182FF
D.I.Y will be a good bit of learning for ya, easiest engine to work on and only 8valves to replace.
  Betty Big Bum R26
had one done before on a 1.2 8v- cost £120 to have the head refurbed. Then obviously new gaskets etc and new belt kit.
Depends what the extent of the damage is, which obviously you'll only find out when you take the head off.
