1.2 turbo mk2
  clio 1.2 16v
Hey
I have a 1.2 mk2 phase2 clio nd want to no if a 1.2 tce 100 engine will be possible to swap any info would be great cheer.
  172 Cup & K20 Ph1
If you're going to go through so much trouble to swap to the 1.2 turbo engine, why not drop the F4R 2.0 into it?
  clio 1.2 16v
Well don't want a big 2.0 its not gonna be for massive performance just a nice amount of power nd talk for daay drivingwith a little bit of a kick nd good fuel ecconomy as have family far away from me
  clio 1.2 16v
Well I been reading nd yes they use the same engine block nd also the same wiring loom nd I don't want a mk3 as I prefer the 2 nd like my car just thought I it could be done for a good price then seems like it could be fun as they have been tuned to 150bhp in the past nd make reali good torque.
  182/RS2/ Turbo/Mk1
I think it would be quite a cool little conversion, but the wiring side of it is likely to be a bit of a headache.
Don
  182 & LY Clio 220 ed
The question is how easily tuned are the 1.2TCE units? (without replacing/adding expensive parts)
  clio 1.2 16v
You can get between 120 nd 130 with a remap nd then exhaust nd filter but k-tec have one at 150bhp I think
  clio 1.2 16v
Well I now know it uses the same block mounts nd posably engine loom
Nd turbo sounds better nd better for my wallet lol
  clio 1.2 16v
These use a td02 unit do depending on internal strenth should see some good power nd torque I would think in answer to how tunable for a 1.2 anyway
  182/RS2/ Turbo/Mk1
Sell it and buy a 172 is the other thing to consider, better brakes, better suspension, cheaper to insure probably.
Plus then you can turbo the 2.0 and go play with the big boys :)
Martin_172
no one has pushed standard internals past 170hp, and only one guy that I know of as pushed past 160hp. quite a few happily pushing out 150hp/150lbft though, all you need is 172/182 injectors, bigger intercooler, exhaust& decat and a good map
id like to do a conversion if I had a spare ph2, as chip says wiring will be your only issue, worst case scenario though just use a twingo dash and wiring.
Martin_172
you could do it for under a grand if your handy, much less if you can map!
£1000 ontop of your £1500 1.2 16v, sure you could buy a 172 for that money but you would have something just as fast and very unique for your cash!
Martin_172
You do realise you cant just plug a laptop in and map the standard ECU, it takes quite a lot of specialised equipment?
well I assume hes not going to be mapping it himself hence why I said you could only do it for less if you can map! of course you wouldn't need to map it to get it running but 100hp isn't much for all the time and money you just spent converting
