1.4 16v engine loom wiring diagram
mikekean
Car  996 C4S, 135i, E30x2
Hi,
Does anyone know where I can get a engine loom wiring diagram for a year 2000 1.4 16v alize clio. My sisteres clio has been had intermitient starting for a while now, but will not start at all anymore which I thought was down to another dodgy TDC sensor, but I replaced the sensor with a new one from Renault and it still doesnt start so I need a diagram to test for wiring faults.
Mike
Does it just crank over?
Like Ben says, check there is feed to the exciter wire on the starter solenoid, if there is and the engine isn't cranking i'd say there was a fault with the starter motor too!
Dan
The wiring diagrams are available on ebay.
Every so often coolant temperature sensors catch Clios out and cause them to flood. Seen it a few times before at work.
Whats the immobiliser light doing on the dash?
It goes off so I dont think its and imobilser issue, I think there is a break in the cables for the TDC sensor somewhere but I need a wiring diagram to find out what pin they are on the ECU plug etc.
