As title says, was looking at getting one or the other but was going to go with VTS as I thought the MPG would be a fair bit better.
But parkers states the VTS as 33 MPG and a 172 as 34 MPG? Is this correct?
I don't see how its physically possible to get the same (if not better?) mpg from a car with 2.0 litre engine weighing a over a ton as appose to a tiny 1.6 made from tin foil that only weighs ~800kg ...
Are you just copying & pasting your responses from Sax-P?
I found my VTS and GTi worse than my 172
Ask anyone thats owned one, they love to be revved and as such return pish fuel economy
Yep. Probably because they lack low down torque and don't make much power until after 4k rpm.
Epic fun though. Much more enjoyable to drive quickly than a 1*2 IMO.
My engine is exactly the same tbh. It's carrying a lot more weight than it does when in the twingo too. So just to pull away you need more revs than you do in most cars.
VVT y0.
You pull away @ 5,000rpm?
Got launch control?
My old hybrid used to do 100 miles to a tenner and ran 13.8 quarters.
Why the f**k did i sell it![]()
i do 40mpg in the Trophy all the time
I used to get 100 miles to a tenner in the VTS driving steady, that was when fuel was just over a quid a litre IIRC.
I'd still have the VTS if I hadn't crashed it, lol. 1.1 is going strong, even after a run in with the rear of a RR Sport! 109k and counting....
To be fair petrol used to be a lot cheaper.
When petrol was low 80p's a litre about 18 months ago you'd only need 38ish mpg to get 100 miles to a tenner.
That same 38mpg will now get you 72 miles.
In reality at todays prices if you get a 172 to do 60 miles to a tenner your doing ok.
