1.6 dynamique engine noise
  m-tec bmw 325 ci spo
i think the 1.6 sounds nice mines got a nice growl to it but it wont turn over in this cold weather i think the guy who sold it to me hasnt put anti freeze init
M
mini-valver
mine doesnt sound like that! Actually think somethings wrong with mine though, lol
  BMW M135i
Sound like mine did pre resonator removal. Does have a nice noise to it. But do this:
Then record it, now thats a proper noise.
  BMW M135i
102mm or there abouts I think, performance difference none I can tell and I don't expect there to be any. Noise difference massively, if you want to hear what it sounds like then take the resonator off and go for a drive it'll heatsoak like mad (which is why the ducting is needed) but it'll sound the same. Its a very deep bellowy noise low down the range and it just sounds ace up the top end.
Its got a K&N panel filter too, that makes a difference as well.
edit:
http://www.venairsport.co.uk/product_info.php?cPath=49_78&products_id=117
Think its that stuff though it could be bigger, I worked out the diameter I needed using Pi.
Pretty sure its that stuff as the circumference of the airbox mouth is ~300mm and 102*pi=320.
Djw John
Scotland - South
mmm think i'll be doing that tomorrow then! Where did you get the ducting from? Im quite surprised how goes the engine sounds already tbh!
  BMW M135i
  Clio
OMFG i have that same problem, think i need to clean out throttle body!
  Clio
OMFG i have that same problem think i need to clean out my throtlle body!!
  Clio
edit:
cheers mate thats some guuurd advice, i want an ITG too :D!
al
  ST on the way...
ITG does give it a bit more growl!! ;)
Can't hear the sound as i'm at work but i'll have a listen when I get home :D
I'll post one of mine too, i've got some "underbonnet" clips :)
  Leon Cupra R 225
Pah! That 1.6 is quiet, ok mine's a Corsa, but has new backbox and induction kit so it's alot louder than that. I think faster too! ;)
  Clio
its that noise that makes it ' seem' faster, even if yours was faster id have you on track ;) !!!
  Clio
ITG anymore performance? yeh get them vids on here :D!!
  Mazda MX5 1.8
actually now u come to mention it....... mine did that once when i left it in a more exposed parking position and when it was rather cold!
f**k knows what it was. that was about 2 years ago now. never done it since
its only happend since its been cold its got anti freeze init i tryed starting it today it took ten turns of the key on and off before it turned over f**king strange mate i cant c what it could be maybe the starter getting frozen ?
  Clio
they are french you know ;) hehehe! i dunno mate, im gonna try and clean out my throttle body with a whole can of carb cleaner and see if that makes it any better??
al
  ST on the way...
Mine used to stall after a cold start occasionally, had to hold revs for about 20 seconds before it was ok.
M
mini-valver
Mine doesnt do any of that buton the odd occasion it has a fit and wont idle unless you give it a bit of a rev.....
  Clio
yup sounds like a common fault then, mine does all that has been said, but like you al if you hold constant 2k revs for 20 seconds its fine :)! weird :S!!!
M
mini-valver
^mine sounds more like yours from inside but really roars near the limiter.....
  BMW M135i
I'd say it roars more up to the top end but the recording is s**te to say the least. Still I think the underbonnet one sounds mental :evil:.
  Clio
dont know whats happened all of a sudden but i appear to have quite a bad missfire, going to change all my plugs to see if that cures it but im thinking it could be a coil? what do you guys think, Cheers Mike.
