16v engine?
  mk2 ph1 1.4 S
now this is logged as a 1.4 16v but it seems to look different to the 16v engines ove seen....
whats the story?
  mk2 ph1 1.4 S
fook sake!
means my cars got a hidden past then! i.e engine swap at some point grr!
unless because mine is the sport its just s different airbox?
  Nissan 350z
I used to own a Ph1 "Si" 16v which had no sunroof, 172 dash, aircon and dual optic headlights.
My friend owned a Ph1 "S" 8v with a sunroof, 172 dash, no aircon and dual optic headlights.
Whoa, whoa, whoa - I'm pretty sure my engine looks like that (in work at the mo) and I've always been led to believe it was a 1.4 16v too.
W. T. F.
I couldn't care less to be honest, doesn't make it any less of a car - just don't understand why I think it's on the v5 that it's a 16v.
  Nissan 350z
In early 1999, a sportive 16V version engine was introduced, and eventually, all the older petrol engines were upgraded to more powerful and more economical 16-valve versions.
1.4 L (1390 cc) | E7J | 8-valve I4 | 75 PS (55 kW; 74 hp) | 1998-2001
1.4 L (1390 cc) | K4J | 16-valve I4 | 98 PS (72 kW; 97 hp) | 1998-present
This is when they introduced the 16v "Si". Which replaced the "S" 8v
Rob
There is a lot of mk2 ph1 16v's every petrol infact.
1.2 16v mk2 ph1 (those tagged with "s" on the side badges I believe) (although I could be wrong about the 1.2)
1.4 16v mk2 ph1 (again "s" tagged)
1.6 16v mk2 ph1 (rsi or RXE I believe)
2.0 16v
  53 Clio's & counting
With the plugs in the side of the head id guess it 8v, though im not 100% on small Renault engines
  mk2 ph1 1.4 S
yeah mines is a 2000 plate 1.4 S badged...
when i put in for insurance it came up with 16v in the title for the car so i assume thats correct?
  Lionel Richie
if people want to fire me their reg numbers or chassis numbers i can confirm if they have 8V or 16V engines
RXE is an 8v
The original picture is 100% an 8 valve engine, I've done a couple of top end rebuilds on them in the last few months
RXE 1.4 16v k4j
Look like a 8v
E7J 626 (maybe but maybe not ;) )
I don't think the insurance told you that i bet the 'S' made you think its a sports car :)
