16v Engines and gearboxs
Is the clio 16v and R19 16v engines and gearboxes totally interchangable. ie can clio engines go in 19s and vice versa, can a clio gearbox go on a 19 engine etc.
  172 cup,s2 rs turbo
virtually the same apart from they are mounted differently in the car(but thats easily solved),gearboxes are internally slightly different and i think the manifolds are different.there are other little differences apart from them but they wont cause much of a problem.easy enough to interchange between vehicles though.
  Titanium 182
just use diff engine mounts
19 has a larger inlet but its more squashed on the clio (smaller bay)
gearboxes are identical.
you can fit a 19 engine in a clio, no need to change manifolds.
  172 cup,s2 rs turbo
from the outside yes but slight differenences internally(ratios sometimes and the diff)
