16v gearbox - wot will fit
knackered my gearbox
clio 16v
took it out the other night so now car is sittin on axle stands in need of box
wot boxes will fit? will a ren 19 1.9D fit? (for price sake)
quaoted of renualt at £398 for clio 16v box
i live in northeren ireland
I think Rens use two different boxes but i cant be sure. Id of though theyd of had all the same box at the time f manu. 19s clios etc
The Williams gearbox has the same ratios, except for a taller 5th gear. Also has uprated bearings and casing - for £550 from Renault. Not suggesting you go for it, but just an idea.
  clio 20v
a more or less standard valver wont pull a willy fifth itll just die when u select fifth unless ur going downhill lol
150 is possible tho more if chipped with enough beans
adi
  BMW 320d Sport
LOL which is why only bad boy valvers run a Willy box. A standard one would be better off with a standard box. If anything I could do with a longer box than the Willy; at 145mph on the GPS speedo, there wasnt a lot of revs left before the limiter, possibly enough to hit 150-155 but no more than that.
