16v Oil Dials in RT
Needing help wirin these up please
got em through today and need to know how to...
mount them??
wire them up??
Al
  Lunar Mk1 & Flamer
alright mate,
you cant actually wire them up to work the engine dossnt have the correct senders. sorry.
how ever you can make them look like they are working! or even wire them up to your break lights so they shoot up when you break etc etc
what i did was take em apart and it was trial and error with a spare 12v battery and 2 wires good luck.
rest of the car is mint
what about the lights?
u can hook up the level and temp to the existing ones on ur normal dash, its jus the oil pressure i think u cant do
make sure ur oil levels aint halved. I tried wiring one to my fuel gauge an i had an inaccurate reading.
For the lighs, rig them up to the headlamp fuse in the passenger fuse box.
  GDI Demo 182, Rsi Spider
you need the corret senders to make anything worth having in there...
its possible to fit the senders without too much grief...
  172 cup,s2 rs turbo
as andi says you need the senders to operate the dials. you could fit an oil level/oil temp sensor of a valver in the original hole for the oil level only sensor on your rt,you might be able to find an oil pressure sensor that would fit in the original place of the oil warning light sensor on your engine and the dials illumination could be wired to an after ing feed.
Cheers fellas,
wot i will need is a picture of a valver with the top dash off so i can see where the dials sit and how they as screwed on
  Trophy
You need the cradle that the dials are screwed into, this is riveted to the dash, youll also need the cover for the hole between both sets of dials if you dont already have it.
I can supply both bits.
Mat.
