Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
as andi says you need the senders to operate the dials. you could fit an oil level/oil temp sensor of a valver in the original hole for the oil level only sensor on your rt,you might be able to find an oil pressure sensor that would fit in the original place of the oil warning light sensor on your engine and the dials illumination could be wired to an after ing feed.
You need the cradle that the dials are screwed into, this is riveted to the dash, youll also need the cover for the hole between both sets of dials if you dont already have it.
