172-200 engine bottom end.
gez 172
Car  Defender 110
Hi all,
just a quick question. Are all F4R Pistons/Rods the same? Or are they different?
As in would a 172 Conrod or Piston be the same as the 197/200 Pistons/Rods?
Im 99.9% sure I know the answer is no, but I thought I'd ask to be 100%
I know the engine code itself is different, the 197/200 is the F4R830 and the 172 is F4R730??
Can someone clarify.
Seen some parts listed as 'F4R' but nothing else.
I know the pistons are different although I'm not 100% on the rods they may be longer.
Rods are the same length, but some pictures laine I think it was put up showed the later ones to be a little heavier.
Pistons are much higher comp on the later engines, they are raised up in the middle to poke right into the chamber, later head is a bigger volume to drop the cr back down a bit, if you put the late pistons with an early head it ends up at about 12:1 iirc
Thanks for the input guys :)
so that clarifys that the rods are the same :)
with regards to the pistons, would Wosner high comp pistons be the same compression in a 172 or 200. Or would the 1*2 high comp ones need to be a different compression?
Cheers for clearing that up Chip :) I thought I'd just clarify :)
i won't bother in that case then. They are just listed as 'F4R' so chances are they'll be for a 1*2 rather than a 197/200
cheers guys :)
