172 brake fluid header tank
Car  Clio 172
Hello guys, as per a recent thread, I need to change the brake fluid header tank on my 172. Does the tank just pull out from the rubber grommets on the master cylinder or is there more to it? Thanks in advance
They just pull out, can be quite tight sometimes though. get as much brake fluid out of it though, as you don't wanna be cleaning that up :)
They just pull out, can be quite tight sometimes though. get as much brake fluid out of it though, as you don't wanna be cleaning that up :smile:
Cheers mate, got a crowbar on it in the end! Turns out it was one of the seals had gone...
