clio (sleeper)
ah right i see.how much will one of them set me back?and then i just leave the wiring for the electronic one there do i?
Also to add to the thread,
buying a used engine is all well and good but ensure you see it running before you fit it. Make sure the drive shafts are good and the gearbox is ok... most cars have been in a crash and the boxes dont survive.
if you get a subframe with your kit make sure it isnt bent.
if the car has an after market alarm fitted when broken ensure that is supplied or you know a good auto electrician who'll be able to fix the loom back up.
ensure that when the loom is removed from the car the upmost care is taken when handling the UCH also if your bits go into storage ensure the UCH is kept dry a new one is over £250 + programming.
as for fitting i prefere over the top but if its all mounted on a good subframe and you have a 4 post, then drop the car over the new built up front end will take you a lot less timewise.
£2500 is a good price - the most fun part is doing the conversion yourself though - you will learn a lot from the experience and feel a sense of achievement when its complete ( and you will save £1000 )![]()
i would love to try it myself but i dont have the tools and if i did it i would have a car either lol.
FAO: Matt, would it be possible to see your the 172cup conversion u have for sale running?
and can you gaurantee the box/dshafts are in good order
as to the aftermarket alarm I'm not so bothered as I'm confident with wiring but it would help to know does the 172cup conversion's loom you have for sale have an aftermarket alarm fitted?
also do you know the mileage of the cup?
Regards Dean
If you have a 99 car with a standard accelerator pedal its easier - simply buy a clio MK1 172 throttle body ( cable type ) and fix that onto the MK2 172 lump. The engines are identical bar the throttle body. Attach the MK1 throttle body onto the MK2 lump and run the accelerator cable from your pedal to the throttle linkage - thats it !!
leon-and-vicky - are you using the MK 2 loom and engine but you want to keep a cable throttle?
no ive sorted it now mate im going to get the electronic accelerator pedel and use that.how come none of this is shown in the pics?because the clio in the pic is a phase one and the engine is out of a mk2 172 it says.and it doesnt show the fuel pump being changed.does all that need to be done too?
mine is a phase 1 aswell.so the rear loom on my car wont plug into the new 172 loom will it?isit easy to wire them together?
thanks
but it is simply a case of one by one finding the line which does the task i.e. engine rpm wire to go to my dials RPM signal input.
Change it to hyraulic power steering then it has a much better feel and less turn to turn than the electric, have you got the column?
