just a quick question,, the near side rear caliper doesnt work on the handbrake but works on the footbrake, does it need a new caliper or can it be adjusted? the handbrake is 10 clicks high, but the dealer said it was right!!!!
you need to unhook the cables from the calipers, pump the pedal a few times, slaken off the adjuster, re attach the cables to the calipers, and re tighten the adjuster
ive taken the plastic cover off the handbrake, but i can find an adjuster . will it be under the rubber cover on the metal bodywork of the car? or is the adjuster under the car? any help is very welcome
yes taken both covers off, and all thers is , is two 10mil nuts holding the actual handbrake to the car, and a rubber cover where the cable comes through, there is no adjuster there at all, its a cup if that makes any difference, thanx
