172 Cup Rear Damper Question
Martin_172
Both my rear dampers are leaking on my 172 (one leaking a bit more than the other!) so need to replace them this week, but was wondering if the 172 cup rear dampers were uprated over the standard 172 ones (i know the fronts are but wasnt sure if they changed the rears or just stuck with the same ones!)
cheers
martin
bump anyone? this thing just nearly put me through a bush backwords when i went round a dry roundabout at 20mph!!!! its dangerous need to order 2 new dampers tomorrow!
think the cups are slightly uprated, part no for the cup rear shocks is 8200662257,
Probably better to change all four I guess and not mix it up.
Do the cup's struts and rear shocks fit the phase 1 172, too?
Change the pair...no point in doing just the one. I had mine go on the rear drivers side, and was recommended to do the pair.
