172 cup stuck on rev limiter
P
Pedron
Hi Guys.
Just got 172 cup on good friday. Very happy with it.
The other day i pulled away from the lights and took it up to the rev limiter. as i change gear it was still stuck on the rev limiter boucing off. i even change in to third and fouth and no change. behind me was a cloud a smoke. smelt like the clutch.
i then came upto a rounabout and it was normal.
im not really sure if its the clutch or ecu messing around.
pete
Sounds like a clutch or something is causing the throttle to jam open. Is yours fly by wire or cable operated?
Everytime i've had a Clio II with an unplugged potentiometer it's held 2k rpm not 'WOT'
did this get sorted I feel like I may be having the same problem I cant stop my engine from being on full throttle...its also ph2 172 2.0 Sport.
