172 - Cup Vs FF Suspension
  Elise S1 B&C 140
I know the cup is lower than the FF but by how much?
Is it just different springs, or are the dampers different aswell?
Finally is it true the cups have a wider track, how is this achieved - Is it just wheel spacers?
Thanks for the help.
Tom
  EV (s)
I know the cup is lower than the FF but by how much? Few MM i think its 5
Is it just different springs, or are the dampers different aswell? Dampers and springs are revised
Finally is it true the cups have a wider track, how is this achieved - Is it just wheel spacers? Wheel offset is ET38.5 no spacers are used. Std offset is ET43 Afaik
  Elise S1 B&C 140
Cheers for the info, next question;
Can anyone recommend a good spring kit, im looking at Apex 30mm or Gmax 25mm, either of these any good?
Tom
  EV (s)
No neither are any good.
The only option for springs is eibach.
Cup was 5mm at the front 7 at the back from memory but the tolerances were tigthening up as ell so ibnfact a normal 172 could be lower both front and rear than a Cup.
Wider rear track ever so slightly via the rear axle setup its tiny though.
