172 - Cup Vs FF Suspension
Car  Elise S1 B&C 140
I know the cup is lower than the FF but by how much?
Is it just different springs, or are the dampers different aswell?
Finally is it true the cups have a wider track, how is this achieved - Is it just wheel spacers?
Thanks for the help.
I know the cup is lower than the FF but by how much? Few MM i think its 5
Is it just different springs, or are the dampers different aswell? Dampers and springs are revised
Finally is it true the cups have a wider track, how is this achieved - Is it just wheel spacers? Wheel offset is ET38.5 no spacers are used. Std offset is ET43 Afaik
Cheers for the info, next question;
Can anyone recommend a good spring kit, im looking at Apex 30mm or Gmax 25mm, either of these any good?
Cup was 5mm at the front 7 at the back from memory but the tolerances were tigthening up as ell so ibnfact a normal 172 could be lower both front and rear than a Cup.
Wider rear track ever so slightly via the rear axle setup its tiny though.
