172 Engine sieze....
Car  F4r'd Clio 1.2 16V
hello after driving along the car suddenly just died and now refuses to start, the starter motor makes a sound of "duh" once and will not actually crank over, tried jumping it after leaving the battery on charge for 2 nights and still just the "duh" coming from the starter, i am thinking seizure the cause i am unsure as it regularly had oil changes etc,
should i be able to turn the crank pulley with the aux belt on or does it need to come off to do this test?
cheers
jack
i knew someone would ask this haha! yes there was oil in it as i am a goon and check the level every couple of days :o
jack
just an update on the situation....
after biting the bullet and going for the strip down we found it had dropped 2 valves which made a hole about an inch diameter in the piston, the cambelt also looks to be caught so could have been the problem, new engine time!
2 valves dropped and you didn't hear anything from the engine worth mentioning
could it be the fact i was probably going 10mph? because there was no noise at all, first thought was i had a paper bag round my airfilter or something :rasp:
