172 geometry settings?
Car  Clio 172 Cup
My 172 Cup understeers really badly at the moment. I had a basic tracking adjustment done by a local garage, and if anything that made matters worse. The front tyres are fairly worn, but not to anything like the extent I would image you'd need to generate that much understeer. So, before I shell out for a new set of tyres all round I'm going to ask the garage to swap the current Conti Sports front-to-rear and double check the geometry.
It's a completely standard Cup (OEM springs, OEM shocks, 16" Turinis, 195/45 tyres). Does anyone know what geo settings it should be running?
I'm assuming the garage would have access to that information anyway, but I thought it was worth double checking before throwing away the current tyres that really don't look that bad to me.
If you want less under steer quickest way is setting 1mm/8-10 minutes of toe out. That'll help. Check what make tyres you have front and rear too and post that up
