Just keep an eye on it, if it continues to use oil then it isnt normal. I filled mine with a whole container of the recommended Renault Evolution oil and mine was still down from the max mark. I never bothered topping it up anymore because it didn`t drop any further, i think it drops because the new oil filter space is filled with oil after you have run the car. So you actually need about 5 litres and a bit to fill it completely.
mine never used to use any but has recently started to use some. bit wierd in that it'll be fine one day then the next day i'll start it up and oil light will be flashing even though they'res no oil on ground. any thoughts on that?
Just keep your eye on it once a week, they shouldnt use too much even when hammered. It will just be beacuse you didnt put enoguh back in on the change after it had sunk down
