172 Powerflex Poly Bushes
Anyone used these?
Ive had them on the mk1 (running 172 wishbones) for around 1000 miles, and when they were removed, the rubber part of the bush seems to have moved/turned round?
The flat spot was at the bottom when fitted, but has moved on all four. The metal part is where it was, its just the rubber thats moved...? Anyone seen anything similar before?
Mine moved a bit, but not that much.
Have you spot welded the steel rings in place btw? Mine came loose! And when I read the instructions it said you must tack weld the rings to the whishbones
nah didnt tack weld them, they were a STUPIDLY tight fit though, took some reet force with the press to get them into place
