172 rear discs and pads
Car  2004 182
Never changed any brakes before but fancy giving this a go as it sounds simple. Anybody ever had trouble getting old ones off? Any tips or hints would be appreciated. Thanks
Nice and easy, 17mm carrier bolts, slide pad retainer out after removing carrier from car, and the small clip holding the retainer. Disc is centre 30mm nut, when refitting, that nut needs to be torqued to 175nm.
Check calipers sliders move freely.
Absolutely no problems at all. Especially the rears.
Lightly slacken the hub nut with the car on the ground.
Jack up
Wheel off
2x 17mms on the pad carrier
Get the hub nut off fully
Disc off
Wind back the caliper piston using a screw driver
New disc on with the disc spacer the right way round. Torque up (not sure how much, I do about 175nm)
locking paperclip type thing on the pad carrier off, slide out the bit it holds in.
Pads out, new pads in
Carrier back on, maybe with a touch of loctite to be safe.
Wheel on
Car down
Pump brakes
ZOOM
EDIT: Damn you @AlexW. At least I got the torque right
Your instructions were much better tbh.
No real need to loosen hub nut before jacking, just make sure car is secure and you have a decent bar.
