182 ARB vs ph1 172 ARB
Martin_172
anyone know if the 182 uses a different/thicker front ARB than the ph1 172? reason being im replacing the full front end setup on my ph1 to freshen it up and while its off thought i may as well do this if its different
I think it may be thicker on a 182, but that would just make the car more understeery.
At the front,is the same,25 mm.In rear axle,for 172 is 22mm and for 182 24mm!!!
nope the 182 has 25 mm at the front (as you said) and the 172 has 23mm. I know this since I ordered a set of powerflex arb bushes to mine-it also says on the powerflex site
We have the (hopefully correct) list here for powerflex
Clio Ph1 2.0 16v RS-172: Outer mount - 22mm, Inner mount - 25mm
Clio Ph2 2.0 16v RS-172: Outer mount - 23mm, Inner mount - 25mm
Clio Ph2 2.0 16v RS-182: Outer mount - 22mm, Inner mount - 25mm
Clio 2.0 16v RS (172 & 182) Cup / Cup pack models: Outer mount - 23mm, Inner mount - 25mm
unless theres a typo from copying and pasting...
I blame someone else...
Kev
Saying that I dont think i've sold a 23mm bush for a 172, only for the williams.
