200 cup & 106 GTi
				Ok, long story. I'll start with an overview, and you can chose to read the rest if you wanna help.
My car has had various handling issues for the past 6 months. It was spot on when i got it, and i've been nice to it but it doesn't seem to care.
Earlier today my rear suspension made a crack noise, which has been followed by a cracking/ting noise which sounds like metal on metal, going over any sort of bump/dip at any speed, even 5mph! It's definitely not the exhaust.
The rear dampers aren't leaking, and the only thing i did to the rear suspension recently was to replace the discs & bearings with new renault ones, torqued with a freshly calibrated torque wrench!
The handling felt much better when i fitted the new discs, but has rapidly deteriorated to as bad as it was before.
I had the tracking done after i fitted the new rear bits, and the car drove much better than it had for a long time, but after overtaking a few cars and an artic on a country road late at night, i braked after pulling in and the rear of the car jumped out, obviously being an experienced track driver i lifted off the brake, corrected and reapplied the brakes, but the car hasn't been the same since. It has been feeling pretty dodgy since october last year, and despite numerous checks and replacing virtually everything it's now at this stage where i can't drive it. The car will sometimes steer itself over cambered or rough surfaces, and sometimes be fine over the same surface on another day. It feels very vague and the back end will start steering the car for no reason on a straight bit of road, making the car crab down the road with corrective steering, only for it to swing back in the other direction when it feels like it, requiring quick reactions! But sometimes it's fine, and if you really push in corners it grips fine and feels OK, but at normal cornering speeds and on straights it feels wrong. If i accelerate on a flat straight bit of road, sometimes when i go to change gear the car will change direction until i reapply throttle, and sometimes be fine...
Any ideas would be greatly appreciated?! I shall be getting the whole rear suspension setup apart tomorrow to have a good look at it, hopefully someone else has had this problem and would care to enlighten me.
