182 cup non starter
Car  Clio Sport 182 Cup
Hello all,
i have a cup 182 05 plate. it ran perfectly fine but then i left it sat for about 3 months. i put a new battery on it and now it turns over but doesnt start. i cant hear the fuel pump kicking in and the red dot on the dash stays on. took it to a local garage and they have got a fault code of df066. they are unsure now and said its main dealer. need some help please.
i'd start looking at the ECU connector as the culprit, its a known weakness on renaults, all too often its the ECU itself that has the flaky connector. take it off and check it out.
its located under the battery tray.
Theres a reset feature and i cant for the life of me remember how its done sure it involves turning the key on and off 3 times or somthing. Search for clio imobiliser reset and you will find it (im on my phone or id find it for you)
i have tried all the resets you can do with the key and fob etc. non worked. is 519automotive still about?
