I have recently had my front shocks changed. On test there was a rattling noise from the front of the car that was not there before,and when checked we found that the first nut that screws into the top,on the threaded bar, was loose. These were tightened again (they were already tight holding the centre still with an allen key whilst being tightened ) and the noise went. However,after just a few hundred miles they were loose again. I used ptfe on the threads to try and prevent them coming loose and re-tightened them (I swung on them to make sure they were tight),but once again the noise is back and I am sure they are loose again. The second time they came loose one of them it was as if the strut had wound itself off rather than the top mounts coming loose. The last nuts that are fitted to the top mounts were always tight,and thats why I say its as if the struts have wound off from below.
Hope the above makes sense...help !
