182 engine/box/suspension
Depends how you want to run it. Run throttle bodies and you don't need any more bits.
If you want to keep stock setup you'll need the looms. Then you need to sort out the ECU, UCH and Keys or a combination and some new ones from Renault.
Would you sell the 182 4-2-1 exhaust manifold seperately?
You haven't put a reserve on it at all. :eek:
For a clio conversion you will need - shafts, loom , ecu , plip key , UCH , clocks, chassis number off vehicle it came from, decoder ring , hubs , knuckles , calipers , discs and eng mounts.
