182 engine whining noise with ignition on
Hi,
My 182 is making a buzzing sound, coming from the engine bay with the ignition on but not engine running, then stops with the engining on, is this normal?
Thanks,
Alex
If you turn the ignition on, but don't start the engine you'll here the throttle body open and close. It's fine.
Thanks for the advice, never heard it before and when it didnt stop was a bit worried.
The reason I was in there in the first place as air con fan isn't working for a few minutes when the car is on...
Was ment to read:
If you turn the ignition on, but don't start the engine and press the throttle pedal you'll here the throttle body open and close. It's fine.
whining noise is there also when not touching throttle , it's fine
all french like to whine...
and drink lots of it too :clown:
