A
ashy_gtt
Now then chaps need your help, just refitted the 182 engine and I have a few problems. Connected everything back up as it was and tried to start the car, thing is it doesn't turn over?
Now Theres a couple of things I'm not 100% sure about, first is are the main fuese in the right order
Can anyone confirm if these are in correctly?
Second thing is there is one wire that I haven't connected and I'm not 100% sure what it was connected to.
Now I haven't got the air con piped back up yet and the front bumper isn't fitted so I don't know if its anything to do with either of them... I'm sure it wont stop the car starting tho?
Anyway, when i connect the battery up and lock / unlock the doors a few times to re-set the alarm it all seems ok, so i put the key in and turn it to to the ignition on position, theres a few things whiring and clicking under the bonnet (throttle body I guess?) then when i turn the key to turn the engine over nothing happens!
The starter is wired up correctly, however I havent checked to see if the solenoid activator wire is getting 12v yet?
Any ideas? Can't help thinking its an imobiliser issue?
Cheers Chaps
Ashy.
Cheers Chaps
Ashy.
