182 Front Wheel Bearing: £££ How much?
Car  Clio 197
This is for an 05 Cupped 182.
I'm interested in how much NEW bearings can be had for.
I'm changing the rears (along with the discs), so I might as well do the fronts too.
:D
Whilst I'm there, is there anything else I can change to sharpen her up?
Ta,
Oms.
Poly bushes but they squeek so you lube then up a lot (ever week or so)
rose bushes will tigten it up as wel but put more load on other bits.
Adjusting the suspension setup can adjsut its hadling depends what you want.
£30 or so for a bearing them you need it pushed in so that £20 at a garave but yi'd have to have the hub off the car for them to do it.
Most garages would want say 1.5 hours labour to do it.
