Quote: Originally posted by MattyMarsh on 09 November 2004
Common problem this on 172/182s. Read this topic -
http://forum.cliosport.net/display_topic_threads.asp?ForumID=2&TopicID=114600&SearchPagePosition=1&search=knock&searchMode=allwords&searchIn=Topic&forum=2&searchSort=dateDESC&ReturnPage=Searchhttp://forum.cliosport.net/display_topic_threads.asp?ForumID=2&TopicID=114600&SearchPagePosition=1&search=knock&searchMode=allwords&searchIn=Topic&forum=2&searchSort=dateDESC&ReturnPage=Search
Quote from dave182-
ok, the clunk when taking your foot off the accelerator at low speeds is not normal and can be cured as I had it from new on mine.
Took it to renault and the fixed it!!!!!!!!!!!!!!!
They adjusted the heat shield as it was positioned wrong, then they tightened an engine mount, and finally my exhaust was bowing in the middle which they rectified.
One of these things fixed the clunk, just not sure which one, but at least you know it can be cured and what they can try. I am guessing this is a common problem so they should have a tech note about it.
Good luck guys and get it sorted, so much nicer without it!
