182 knock + abs lights, serv etc
Driving along in traffic in 1st, put foot on gas, take off and theres a knock or click from what seems to be the rear / drivers side of the car.
Anyone had similar.
Can someone also remind me what the prob is when all the ABS, Serv etc lights (3 in total come on) Ive had it 3 times in as many days.
Cheers.
Nik
ClioSport Admin
  Clio Trophy #355
Does it go off when you switch off the ignition and turn it back on again?
Its one of the common faults.
Interesting how loads of people have posted about this problem in the last few weeks. Mine had stopped doing this then all of a sudden after about a year off, its come back. Does it most days now too, usually near the start of a journey i find though.
Wondering if the ABS sensors are sensitive to the cold wet weather?
[Edited by NikC172 on 09 November 2004 at 9:52pm]
  Black 182 + Recaros
Common problem this on 172/182s. Read this topic -
http://forum.cliosport.net/display_topic_threads.asp?ForumID=2&TopicID=114600&SearchPagePosition=1&search=knock&searchMode=allwords&searchIn=Topic&forum=2&searchSort=dateDESC&ReturnPage=Searchhttp://forum.cliosport.net/display_topic_threads.asp?ForumID=2&TopicID=114600&SearchPagePosition=1&search=knock&searchMode=allwords&searchIn=Topic&forum=2&searchSort=dateDESC&ReturnPage=Search
Quote from dave182-
ok, the clunk when taking your foot off the accelerator at low speeds is not normal and can be cured as I had it from new on mine.
Took it to renault and the fixed it!!!!!!!!!!!!!!!
They adjusted the heat shield as it was positioned wrong, then they tightened an engine mount, and finally my exhaust was bowing in the middle which they rectified.
One of these things fixed the clunk, just not sure which one, but at least you know it can be cured and what they can try. I am guessing this is a common problem so they should have a tech note about it.
Good luck guys and get it sorted, so much nicer without it!
funny that i thought my stop light came on the other day ?, wasnt sure as i saw it out of the corner of my eye
dk
  911 GTS Cab
Quote from dave182-
Thanks Matty, was just about to get on my high horse when I noticed you had saved me the job, thanks!
  Arctic Blue 182
I took my 182 in re: the knock (mine does it too), but it came back still doing it. It shall be going back.
  172 cup,s2 rs turbo
faz182-what did they say? i didnt personally do the job after the roadtest as i have to much to do on a saturday.
Jay / Faz - Was this Lambs in Chesterfield? Thats where mine will be going.
Jay - do you work there? If so can I ask you take a look at it?
  Black 182 + Recaros
dav182 - yes I thought you might ;).
This is another one of those topics that keeps coming up again and again. I keep hoping it will go away when Renault fix this bl**dy problem :mad:.
Took mine in for the Knocking thay gave me a load of s**t and didnt fix it well not compleatly.... it does it less so its now harder to re-create the problem to another technician....... was gonna leave it till it goes in for the first service!!! it also does it sometimes when you turn the car on and off!!!!!
RE the Lights thing...... there is a little black box under the passenger seat.... wiggle this and hey presto!!! they go out... do you use you back seats alot? I find it normally happens when the P seat is pushed right forward before a journey?
any comments?
  Arctic Blue 182
Heyup mate!
Well, the bloke who handed me the keys said that James (dont know if that meant you) had a look and just tightened a few bolts underneath, and to see if that cured it. That was it, and I left.
It is still doing it tho.
  Arctic Blue 182
Quote: Originally posted by Jason C on 10 November 2004
Jay / Faz - Was this Lambs in Chesterfield? Thats where mine will be going.Jay - do you work there? If so can I ask you take a look at it?
Yes, this was Lambs in Chesterfield. Bought my car there, and theyve generally been very good to me, so it will be going back in until its fixed. As dave182 said its a problem, not a feature.
My 182 had the 3 lights come on within 1/2 mile of picking up (motorpoint, not dealer). gf took it in at the weekend, and apparently its some ABS wiring behind the steering wheel? (assume that means position sensor on the wheel? - Im in the US for 4 more weeks, and just going on what shes told me!) Can anyone clarify a bit more?
Apparently a 4Hr fix, and has to go in a week Saturday - and theyre not going to have it ready till the monday. I really hope it isnt going to be used as a weekend runaround while its there, especially as it hasnt hit the magic 650 miles yet.. (probably paranoia I know, but Im sure everyone here worries a bit when handing over the keys to their favourite toy!)
Hopefully itll all work though - its certainly taken the shine off owning my first brand new car, thats for sure...
