Re: Update!
They will fob you off and tell you to buy the whole arm, tell them to smoke your pole.
			Gave the car to Tony (Service Manager at Jaybee) last night and he took the fault description "loud knocking sound from front right in straight line and loud creaking noise when steering, at speeds up to approx 30mph" and told him I thought it was the bottom ball joint... his mechanics got hold of the jobsheet and dug out the Renault "Technical Note" for the top strut knock which reads something like "muffled knocking sound from axle on extremes of steering lock when maneuvering at slow speed" and pre-emptively ordered.... drumroll.... TWO WASHERS! YAY! :lolup:
Just picked it up from his house and he said to me "It's not fixed but the part's on order... go on, have a guess what it was...", I said "Bottom ball joint?"... "Spot on."
Bless the Renault monkeys and their cotton socks :S I'm taking it in on Tuesday morning and having a while-u-wait (maybe 2 hours apparently) job on it because the next time I'll be around two evenings on the trot is next Thursday, due to work :dapprove:
So nearly sorted, thanks for all the advice folks!
Those of you that are local to me who have been having problems with dealers might want to take it to Jaybee Motors in Bodicote (outskirts of Banbury) because they've always been very good for me... the chap who worked on my car is apparently the son of a Trophy owner, and found the fault almost immediately!
Edit: also had the polarity of my ultransonics swapped while it was in the garage to solve the alarm problem, and they also did an "alarm siren modification" which is dictated by a Renault Technical Note... anyone know what that is?
So the problem was a damage lower arm Ball Joint?, I will go to check if the dealer has ball joints![]()
