JToroPaz
								Renault Clio 182
				Got a bit of a strange intermittent issue. Day to day car runs fine, starts fine, doesnt idle high, revs fine and pulls fine. Then at motorway speeds it'll randomly loose power, slow to 50mph and sound like its either misfiring or being limited to 50mph. Similar sound to a pit limiter on a race car (see video)
Checked both spark plugs and injectors and both are fine, cam belt was replaced June 2021 (Ive owned it since November 2021). Work was done at a Honda dealer in Bradford not a Renault specialist, wouldnt really explain why its so intermittent but wondering if the timing is wrong.
I have gotten a check engine light yesterday after stopping off somewhere, then on start up the light was on.
What do you think, cambelt timing? Something else maybe ecu or sensor related? Trying to determine which way to go to solve it because its clearly not happy for some reason!
2004 Renault Clio 182 FF
117,000mi
Cam belt done June 2021
Other work in past 12 mo:
New water pump
radiator
alternator
K&N air filter
full decat scorpion exhaust
top and lower polybushed engine mounts
All work done before ownership, owned since Nov 2021
Video showing problem:
117,000mi
New water pump
radiator
alternator
K&N air filter
