182 rear beam different to 182 cup?
Car  Clio 182
So I've just been told that the 182 full fat rear beam is different to the 182 cup/cup pack. Apparently it's wider?
i didn't think it was, but didn't know for certain. If it is, why lol? I don't see the point in creating 2 different rear beams for the same car...
regards
Dan
I doubt its wider lol...Who told you that??
Well I'm looking for one to buy and I pm'd someone and they said a bit of advice, the 182 full fat and 182 cup beams are different, but I don't see how or why it would be?
It's just the hubs that are different in thickness. These can be swapped over anyway.
As in the bit that the stub axle is pressed into. If so that's bad because I need them too! Would it matter of I were to just swap the complete beam onto my car, including the non cup hubs and stub axles, or are the stub axles different thicknesses too?
regards
Its just the stub axles that are a different thickness's, you should get away with the complete beam depending on your wheel offset. I would buy it tbh as you will get a wider track if it works, if not just swap the stub's over.
This is what I quoted to you
A bit of friendly advice would be that it has to be from a 182 cup or with cup packs as they're different widths to normal 182's, 172's and 172 cups
