That's a statement from the DOT.
As there are no UK regs, the European regs are adopted. This is the full letter of response from the Department Of transport
"The situation for Gas Discharge (HID High Intensity Discharge) (commonly known as Xenon) headlamps is complex.
I attach links to the Road Vehicle Lighting Regulations 1989 which regulate the situation in the UK.
Under these Regulations Xenon headlamps are not mentioned and therefore they are not permitted according to the strict letter of the law.
However you will be well aware that new vehicles have Xenon headlamps. This is because they comply to European type approval Regulations. The UK cannot refuse to register a vehicle with a European type approval. These are to ECE Regulation 98 (for the Xenon headlamps which are tested on a rig in a laboratory) and ECE Regulation 48 (Lighting Installation on the vehicle).
For the aftermarket, a used vehicle cannot obtain type approval because it is only applicable for new vehicles. However we feel that saying "Xenon is banned in the aftermarket" would not be reasonable. Instead we should make analogies with new vehicles. It would be reasonable to require Xenon in the aftermarket to meet the same safety standards as on new vehicles. The same level of safety should apply.
Therefore a Xenon headlamp sold in the aftermarket should:
1. be type approved to ECE Regulation 98 as a component.
2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place).
3, Comply with RVLR as far as "use" is concerned.
In practice this means:
1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp. "
But as long as you have them aligned correctly and keep them clean I can't see you ever getting into any bother over it.
