when setting off from cold our 197 bunny hops. bad clutch control, you would think. Its so hard if you set off quick.Fine when warm.
Still under waranty.Anyone heard of a fault.
Does the traction control do this?asp or what ever its called
Even when warm, sometimes out goes like split shi*, pulling quite well from above 2k.Other times its flat all the way through, hitting 5k and stays flat
