It was just an idea!!!! to decrease rpm at high speed.
Dan! in my country the speedlimit on highway is not 70mph legally it's 81 but to 94mph (150km/h) you won't pay fine. so at 94mph the engine revs about 4400.
thanks Dan that was the info what I need ( your revs more) and thanks for Marinemakay &Mr.Pink longer 5th will be the solution.
I have no problem with the loundness of the engine and the car too. I love it! I thouhgt this forum is for talking about the cars, ideas, intrests, etc.Solution is a different car or earplugs. If you had longer gear ratios (the gearbox from the Clio DCI is the JC5 gearbox which is the same as the 172, however it has much longer ratios, 4500rpm in 5th is 125mph) then it will be a pig to drive.
Fit a Clio dci 80/100 gearbox, direct fit, results in lower rpm
Seems a popular thing amongst the boosted boys
