2 Small black relays
Car  172cup
Am I right by saying there's 2 under the bonnet next to each other as mine has one and next it someone has bypassed it with clips/fuse/wire contraption I brought 2 and replace mine it wouldn't start, I put the wire/fuse back in (right hand one as you look at it) and it starts any one know why they have bypass it. Thank's
Yeah 1 I believe is for the radiator fan speed and the other will be for your fuel pump. The relay board can become corroded to the point where it is easier to make a new connection with the wiring and the relay than to replace the whole thing. The person who done it may have had trouble with the relay and instead of replacing it, just bypassed the relay instead.
Ok thank's when I put a relay in instead of the fuse it won't even turn over totally dead plug the fuse in and starts ok
