2 Very Quick Audio Related Questions...
  Coiley'd Clio PH2
Right, i have two quick questions that i need answering.
First one: Will this speaker cable be adequate for door speakers? Is it the right Gauge etc...
http://www.theloudest.co.uk/?sectionid=2&page=view_product&product_id=101
Second One: What are the following wires for in the picture?
I understand that there would be 8 in total for four speakers (Front and Rear: Left and Right, Positive and Negative) but what are the other four wires for? Do they need to be there?
Nick
  Clio MK2 (1.2)
U can use any wires really, iv used a speaker wire to do as the Remote on the Amp to the Headunit, works fine not problemos atall, go to B&Q and get a Roll from there, or go to your Builders Merchant
  Coiley'd Clio PH2
But what are the extra cables for?
Surely to do four speakers and two separate tweeters you need 8 lengths of wire. 2 to do rear right speaker, 2 to do rear left speaker, 2 to do front right speaker and tweeter and 2 to do front left speaker and tweeter.
My understanding is that the wire for the front speakers splits up and another two separate wires go up to the tweeter and two go to the woofer.
  172
right from the picture as you look at it i will number the block
1234
5678
1 and 5 for speaker in rear
4 and 8 for speaker in rear
2 and 6 1 from each goes to the woofer
the other 1 from 2 and 6 goes to the tweeter
3 and 7 1 from each goes to the woofer
the other 1 from 3 and 7 goes to the tweeter
cant remember which side is which right now,only just got up
