Just tried to order some 3/4 plates on www.fancyplates.com using revels guide on here, everything is fine except there is no option for 520x84mm. You can only have standard size or 380x84mm, what am I doing wrong?
Also the picture in the plate calculator shows no spacing between the first 4 and the last 3 characters which will just be blatantly illegal, do they come like this or do you need to specify?
Has anyone fitted a fancy plate to the rear in standard size as well, does the font come the same size as standard uk plate?
Any advice welcomed.
Morgan
Morgan
