R3k1355
Not mine, just spotted on eBay. Looks amazingly tidy.
Exterior:
Glacier white
Cup side skirts
Cup front splitter
Cup spoiler
X4 Team Dynamic 1.2s finished In Anthracite with Michelin PS4
Heated windscreen
Suspension/Chassis
Avo dampers with custom spring rates (full coilover rear)
Rene Dizdar upgraded swivel hub bearings
Powder coated rear axle
Powder coated front subframe
Powder coated lower arms
Blasted swivels and hubs
Adjustable drop links
Poly bushed rear axle
Poly bush front arms
Shimmed rear axle
Cooksport performance geo set up
Brakes:
Refurbished 197 Brembo callipers in white
Refurbished rear callipers
God speed 330MM discs
EBC pads front & rear
Braided lines front, rear and underneath. (Whole new system)
Front and rear Brake pressure sensors (displayed on the ECU master dash)
ABS stlll retained via MAXX ECU
Interior:
Sabelt GT3 Bucket seats
Wheeler motorsport side mounts
JC clubsport rear seat delete
Alcantara headliner and sun visors
ECU master ADU5 dash with carbon surround
ECU master keyboard
Carbon fibre centre console with iPad display
Rentune ignition switch
ZPO shifter
SW motorsport half cage in anthracite
TRS harnesses
Renault sport floor mats
Heated windscreen
Electrical:
Maxx ECU Race
X2 ECU master 16 channel PMU
ECU master Dual H bridge
ECU master ADU5 dash display
ECU master 12 Button can bus Keyboard
Custom Chassis Loom from Rentune
Custom engine loom from Rentune
Rentune canbus steering wheel controls with stalk delete
Rentune battery isolator
Rentune 3D printed ignition switch
Quick release wheel with canbus controls
Battery relocation kit
Sensors:
Brake pressure sensors front and rear
Wheel speed sensors front and rear
Coolant temp sensor
Coolant pressure sensor
Oil temp sensor
Oil pressure sensor
Fuel temp sensor
Fuel pressure sensor
EGT sensors for each individual cylinder
Downpipe EGT sensor
Clutch pressure sensor
Boost pressure sensor
Exhaust gas pressure sensor
AIT sensor
AFR sensor
Meth pressure sensor
Gearbox:
Megane 2 NDO gearbox
Super finished gear set
Aqua blasted gearbox casing
Race Spec Gripper LSD
New diff bearings
New output and input shaft bearings
New synchros from 2nd -5th
AP concentric slave cylinder conversion with pressure sensor
TTV single mass flywheel
TTV twin plate clutch
ZPO shifter with Anthracite Knob
Vibratechnics gear box mount
Fuelling:
Bosch 1000CC injectors
Megane 250 sender unit
Swirl pot with internal Bosch fuel pump
KTEC fuel rail with return
New fuel lines through out.
Sytec fuel pressure regulator
Cooling hardware:
Custom 100MM FMIC
Custom radiator and fan set up
OBP expansion tank
Custom coolant lines
Heater box delete
Aircon delete
Cool boost water meth system
Custom 70MM boost pipes
Custom intake
Engine:
Megane 225 Block
CLIO 197 Cylinder head
Decked block for correct squish on the
83MM wossner pistons with modified valve pockets
PEC rods
197 polished crank
197 exhaust cam
182 inlet cam
ARP head bolts
ARP rod bolts
Supertech valves with double valve springs
New lifters
New shells
New bearings
New oil pump
Painted block
Aqua blasted rocker cover and cambelt covers
VVT
Vibratechnics engine mounts
Turbo/Exhaust
Garret G30-660 .72 AR externally gated turbo
Tial wastegate
Custom BL motorsport side winder manifold (heat wrapped)
Custom BL motorsport 3inch turbo back resonated system (V-band system)
Screamer pipe plumbed back into downpipe
Custom turbo brackets
Intake:
Megane 250 inlet
Ford 1.6 MK7 throttle body
Custom intake with ITG filter (located in wheel arch)
Custom enlarged boost pipes with blue silicon hoses.
Tuning:
Tuned by rogerclark motorsport on Maxx ECU
3 Boost settings
Wastegate 380BHP
Medium boost 440bhp
High boost 551bhp/440LBFT
12 level traction control system on a rotary switch via the steering wheel controls. (12 fully on 1 off)
3 level anti lag system via rotary switches
Clio 197 Cup (Garret G30-660 551BHP) | eBay
Find many great new & used options and get the best deals for Clio 197 Cup (Garret G30-660 551BHP) at the best online prices at eBay! Free delivery for many products.
www.ebay.co.uk
