90 Amp in-line fuse
coolspot007007
Car  Seat Leon Cupra
Hi, i bought the autoleads 60 amp wiring kit, but my new amp needs a 90 amp in-line fuse. Can you get a 90 amp glass fuse that fits? Or do i need a new fuse and holder?
To be honest you *should* use a 90 amp lead and fuse. If you use a lower ampage wire it *could* get too hot and burn out
The amp is a kicker ZR600, uses 3x 30amp fuses, you get a 90 amp fuse for the power cable when you buy it, but i got it 2nd hand so it wasnt included.
get a 100 amp in line fuse and some fat power cable able to take 90 amps, because the 60 amp cable definetly wont!! in fact if you used a 60 amp wiring kit and a 90 amp fuse, the wiring would all burn out and you would be left with a fuse only!!! 100 amp is okay, but one of the individual fuses would blow before the in line anyway.
hope this helps
