Does anyone know what involved if i was to remove the Air conditioning from my 172FF ?
For all the times i use it...
Is it just a case of unbolting the Air Conditioning pump and getting a shorter aux belt ?
And removing all the pipework that goes into the car from the A/c Pump after de-pressurising the pipework through one of the schraeder valves ?
And then unplug all the electrical connectors and tape them up out the way ?
Or is there more to it than that as my car has climate control ? :S
And would i be able to just unbolt the pump and use a 172cup aux belt setup in replacement of the standard 172FF aux belt ?
Or do i need new pullys and tensioners etc ?
Your help is appreciated ?
