ABS Problem - Pluged into Snap-on Diagnostic
Car  Black PH2 172
Had no time atall lately, Borrowed my mates Snap-on Diagnostic thing for the ABS fault code and had number;
5:Power to solonoid valve or somthing along the lines..
6:One of the 4 wheel targets which I asssume is one of the ABS sensors
Going to try take the wheels off and have a look one evening this week, Can anybody shed any light on these those? Unsure on the Solonoid valve? And what obvious things to look for on the ABS sensors, Wear etc?
Regards Tom
If its referring to target surely that would mean the reluctor ring? Maybe rusted or Cracked, unless the sensor is telling the the ABS ECU the wheel is moving at a different speed than the other 3 cause its faulty?
Just a thought, i think the advise you will get is if the rings are in good shape, the sensor would need putting on a oscilloscope and the wave form checking, the sensor its self should read 1200ohms by the way.
What about power to the solonoid valve? Anyone come accross that? I spose check fuses and wiring?
Rings look fine - Ive cleaned them all up and seem to have sorted it, Havnt had a chance to proply drive it but seems as though its cured it, Driveshaft inner boot in the middle of the shaft is rubbing against sump tho :/
Hasnt sorted it! I'll check rear abs rings tomorrow, Brake Pedal still goes hard if I boot it! When engine is running and I can hear air of some sort coming from the brake pedal when I push it up and down..
