2003 Clio 172
So right, my wee clio has been doing micro abs farts since I got it.
Nothing major, just occasionally when braking (very very lightly might i add, say at 10mph) i feel the occasional pulse of ABS through the pedal.
So many here advised ABS rings but under inspection, i couldnt see a thing apart from rust on one side and rust/grease on the other from an old cv split.
I couldnt see the rears without removing the discs so had resigned myself to putting up with it until i changed the rear discs in a month or so.
But last night while I was under the car, i gave the fronts a good going over with a wire brush......
Low and behold under the rust, I found a giant crack in the passenger ABS ring.
At least that explains it and i just thought i would give everyone who is facing the problem a heads up. Scrub the rings first
On a side note, i see 44 teeth reluctor rings on eBay for like £10........are these ok? Anyone used these? Or is this an item that should be replaced with a Renault item
Jj
Jj
