Abs removed on clio 172
Car  Clio 182 rep
Abs removed on clio 172 all wires took out and pump how is it best to get the abs light off so don't come back it possible to remove it from ecu
Fit a cup master cylinder and brake pipes.
With the pump still there and the wires cut off the car will end up locking the rears as braking is split 50/50 and doesn't function properly. It is effectivley working in safe mode.
Im assuming it's on a track car? Only wonder as I think it's an MOT failure for it to have it and it not be working, whether the light be on or off.
In relation to the light though, a CLIP might be able to turn the light out, alternatively take the dial cluster out and put some tape over that LED that illuminates that symbol!
