ABS Ring wont fit!
  clio 182
ive bought a new ABS ring as i broke the other, but it wont go on the back of the dics, but it looks exactly the same as the old one, same amount of teeth?
was wondering if you needed to heat them up to expand them abit or somthing?
DrR
  VW Golf GTD
If it only just won't fit try heating it, but if it's way off no chance.
  Mondeo TDCI 130
Generally they just need a bit of persuasion! There made of cheese though and bend quite easily!!
Jaff.
theyre a shrink fit usually. so need to be heated up put on and then let to cool down, then they stay on :)
  Dodgy one
I warmed mine up on the driveshaft with the blowtorch, bit of grease on the shaft and a punch and it went on no problem!
