ABS teeth size
  Clio 182 sport
Sorry i have searched and think i've already got the answer but want to double check before ordering new discs ive got an 04 plate clio 182 sport ... are the rear abs rings all 44 teeth and any advice for the front ones as im gonna change them all same time as the pads,discs,bearings,ball joint before the new mot ,many thanks in advance
  Clio 182 sport
okies cheers anyhoos ..been checking online car parts via reg plate but cant anyone doing the abs rings :(
  PH2 172
Cheers bro are the rears 44s ?
I have just looked through eBay,and it would seem that 172`s had the same 44t x 75mm i/d x 7.5mm width rings front & rear.
Later 182 would seem to have wider front 44 x 75mm x 15mm,but retain the 7.5mm rear.
J&R list 7.5mm rear as item no 13060435204 & 15mm as item no 17121804020.
They do NOT list 13060435204 as front & rear,nor list a 7.5mm front,as I suspect there is no problem with replacing a 7.5mm with 15mm.
They are £1.99 rear & £2.49 front per piece.
There are other products to choose from.Seach clio 182/172 abs ring relustor.
Dan,which width did you use?
  Clio 182 sport
You sir are a star many many thanks ... the rear discs come with the ring already fitted and dont mention width just either 26 or 44 teeth ..i can order the 44s now awesome stuff and ty again :)
  PH2 172
You sir are a star many many thanks ... the rear discs come with the ring already fitted and dont mention width just either 26 or 44 teeth ..i can order the 44s now awesome stuff and ty again :smile:
26t rears are 1991 Mk1 clio.
Rear OE Renault discs come with ABS rings ,& bearings as you say,around £100 the pair.
imprezaworks
  Mk5 Golf GTI :)
Which width ring?
15 mate
  PH2 172
i thought as much but they refused to send them out till i could confirm the amount of teeth and made me question myself tbh ... and they are supposed to be the car specialists ..go figure ... im getting these http://www.ebay.co.uk/itm/Renault-C...652978?hash=item43e60149f2:g:h2oAAOxy9dVTkzXw
Up to you.Drilled discs have a tendancy to crack between the drillings.
I would suggest brembo pads all round,genuine rear discs & brembo plain HC front discs for a similar budget.
Kam Racing is a good place to start comparing prices.
  dan's cast offs.
give them a year or so and they will be peeling apart, seen it plenty of times with them. it's almost like the de laminate.
  PH2 172
give them a year or so and they will be peeling apart, seen it plenty of times with them. it's almost like they de laminate.
Are you referring To J&R abs rings?
Could be,but they have mega 146k 99.9 % pos rating on eBay.
You pays your money & live with the choice.
I have not given a personal recommendation to any J&R product,
  Clio 182 sport
upon your advice i did a spot of reading up and decided to go for standard discs ..thanks for the heads up on these you've probably save me a fortune in the long run mate
